I set up the Processing - 2D products window as follows:
checked on create contours
output format= SHP
contour settings- base=0 elev interval-10
I executed the process and, after some hours of crunching, it completed, but I can't find the contour SHP file anywhere. Where's the default output location?
The contours should be in C:\Users\<user>\Documents\Drone2Map Projects\<project>\products\2D\Contours
