AnsweredAssumed Answered
Copy production Database and "rename" as test database - what is the proper workflow?
Question asked by MollyKFoley on Sep 29, 2017
Latest reply on Sep 29, 2017 by George_Thompson-esristaff
I have a database in production and need to update an old copy of it, the "test" database, where I can only assume the person in this position before me did a backup & restore to create the test database, but renamed it during the restore process  thus I cannot actually connect to it in ArcMap because all the SDE tables have the production database name, not whatever he renamed it to (cause renaming is a no-no with SDE geodatabases). I can't revert this test database back to the original name because the production database exists in the same SQL Server instance and you can't have two databases named the same. Plus, the data in it is old and I want to update it.
So, what is the proper workflow for creating a copy of a database with a new name? I'm thinking it'd look something like this:
1) Use Create Enterprise Geodatabase tool with the new name "MyDatabaseTest"
2) Add users (is there any way to copy users from the production database to the new test one or do you really have to go through and do it manually again?)
3) Use ArcCatalog to copy/paste feature classes and tables from production database to new test database
How does this copy/paste process affect existing table relationships in the RDMS? I worry about losing all of that.
Will this workflow work? I assume after going through this, I would be able to use direct connection in ArcMap to connect to the new test database, as that is really the goal.
For reference, working with SQL Server 2014 and Desktop 10.5. I'm not sure what version of SDE we're working with, if it's the same as Server it'd be 10.4.1.
Outcomes
