GeoEvent with ArcGIS Online
2104
09-28-2017 07:53 AM
KB1
I haven't seen if this is yet possible or when hopefully it will be available.  Currently we only use the ArcGIS Online environment and do not have ArcGIS for Server.  We would like to utilize the GeoEvent features but it looks like without ArcGIS for server that is not possible.  Can someone please confirm that?
If that is the case, has there been mention of releasing a GeoEvent extension for ArcGIS Online?
Thanks.
Greg_Mattis
Occasional Contributor II
For GeoEvent Server, you would need ArcGIS Enterprise. From then you can take the resulting feature service and bring that into ArcGIS Online. What is it that you are looking to do with GeoEvent and what is the limiting factor for not using ArcGIS Enterprise with GeoEvent Server?
Greg Mattis, GISP
GIS Analyst
City of Visalia
by Anonymous User
Not applicable
Hi Greg,
I am having a similar query..
1) Why cannot we use on-prem installation of Geovent server with arcgis online utilizing stream services way? When we dont have on-prem arcgis enterprise setup in place
2) our architecture is designed with arcgis online and we don't need on-prem portal for arcgis then are you saying it is impossible to use geoevent server??
Please confirm
BR
GregoryChristakos
Hi Saurabh,
Most often at a minimum, all you need to utilize ArcGIS GeoEvent Server is an installation of ArcGIS Server (licensed as GeoEvent), and then an installation of GeoEvent Server on the same machine. This type of set up should be sufficient to allow you to read from ArcGIS Online feature services, and subsequently write to ArcGIS Online feature services. Its not necessary that you install and configure a Portal + other supporting ArcGIS Enterprise elements. Its important to note however that stream services (from GeoEvent Server) cannot be published/hosted in ArcGIS Online. They have to be published to the underlying ArcGIS Server since they run as a part of the GeoEvent Server service (to really generalize things here). You can certainly add the stream services to your ArcGIS Online organization as items (just as you would with a non-hosted map/feature service), but the stream service still needs to be published & running on the GeoEvent Server machine.
If you are primarily working with ArcGIS Online already, you don't have a need for an on-premise Portal (or ArcGIS Enterprise for that matter), nor do you want to deal with the infrastructure aspects of managing GeoEvent Server, we do offer a new product called ArcGIS Velocity which could likely fit your needs. Velocity is a new capability of ArcGIS Online that provide real-time and big data processing & analytic capabilities. With it, you can ingest real-time data, perform on-the-fly analytics, and even output it to feature/stream services hosted in ArcGIS Online (and more). Since ArcGIS Velocity is a SaaS, there's nothing for you to manage in terms of infrastructure. Everything is hosted in ArcGIS Online. Something worth considering given your questions!
Hope this helps!
