AnsweredAssumed Answered
ArcGIS Pro Temporal Mosaic Dataset seemingly 'stuck' on cumulative
Question asked by tomas1 on Sep 27, 2017
I have created a temporal mosaic dataset and am able to to use the time slider to run through the images in ArcGIS Pro.  However, the display sequence is cumulative, not 'removing' previous versions during playback.  I looked at the options on the  Time tab and have not been able to find anyway to overcome this.  The same mosaic dataset plays properly in ArcMap.  I have looked for the ArcGIS Pro equivalent of the ArcMap setting 'Display data cumulatively' in Pro with no luck.  I am assuming somehow this setting has been assigned in Pro to show the data cumulatively, which is not what I want.  If this is the case, I need to know how to disable the cumulative parameter.
If my grief is not associated with a setting, any insight regarding the behavior of mosaic datasets that might cause this issue would be welcome.
Any assistance is greatly appreciated.
Outcomes
