Is it possible to add overhang to a pyramid roof and a shed Overhang?
970
09-24-2017 10:29 AM
CarlaBernecoli
Hi all.
 Is it possible to add overhang to a pyramid roof and a shed roof?
Like the overhang attribute in a Gable roof and  Hip roof.
Any suggestions?
DevinLavigne
Occasional Contributor III
This isn't always perfect, but it's a trick I use and works well - I scale up the roofplane and then center it.
 * File:    Geonet_Overhang.cga
 * Created: 27 Sep 2017 15:58:51 GMT
 * Author:  Devin Lavigne
version "2017.0"
#THIS IS A PERCENTAGE
@Range(1.0,2.0)
attr overHang=1
@Range("Shed","Pyramid")
attr roofStyle = "Shed"
@StartRule
Generate-->
     extrude(10)
     comp(f) {top:RoofPlane | side:Wall}
RoofPlane-->
     s('1*overHang,'1*overHang,'1) center(xy)
     BuildRoof
BuildRoof-->
     case roofStyle=="Shed": roofShed(10)
     else: roofPyramid(40)
LR
Here's some ancient code I wrote once to make a "true" overhang, unfortunately it only works properly for buildings with equal width and depth due to the trig used to calculate the y-offset. You could always eyeball it, though. Or just change it to have a floating "tent" hovering close above the structure.
attr overHang = 5
attr roofAngle = 30
@StartRule
Lot -->
 extrude(1)
 s(20,10,20)
 center(xz)
 comp(f){top: Roof RoofOverhang| all: NIL.}
Roof -->
 roofPyramid(roofAngle)
RoofOverhang -->
 s(scope.sx+overHang*2, scope.sy+overHang*2,'1)
 center(xz)
 split(y){overHang*tan(roofAngle): Overhang | ~1: NIL}
Overhang -->
 t(0,-(overHang)*tan(roofAngle),0)
 comp(f){top: styleOverhang | bottom: NIL}‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
CarlaBernecoli
Thanks!
