Support for setting/resetting renderers?
297
09-21-2017 09:51 AM
AndrewRay1
Is there a plan on when there might be support for setting and re-setting renderers in the python API.  i have a number of maps that are being duplicated for multiple purposes but the upper and lower end range of a dataset used in a classbrakerender changes with each copy.  i have worked around lack of support by using the REST API to call the (/generateRenderer) function on each layer but then updating the breaks and handling rounding is a pain, a simple option to allow us to set the renderer based on some settings would be very much appreciated.
Does anyone else have this problem?
