sladinj
Duplicate Feature After Search
Discussion created by sladinj on Sep 19, 2017
So, I have several features set up in my map for GPS Collection to be able to search by ID number.  I've noticed that when I use the Search function in Collector, it "creates" what appears to be a copy of the searched feature.  It doesn't add it to our feature layer, but if you unselect and then reselect the feature, it shows both (or if you've done multiple searches of the same feature, it has multiple copies).  It even has a smaller symbol than our actual feature.  The only way to remove them is to close the map and reload it.
Anyone else notice this or know how I can keep the searched feature from showing multiple times?  Here's some screen shots:
Searching for Valve by Valve ID:
Searching for Valve ID
Search Results:
Search Results
Selected Features and First valve is the actual valve:
Actual Valve Selected
Next (and the following) are previous searches (notice the difference in symbol size in the Detail Window):##
Search Result Valve
Outcomes
