AnsweredAssumed Answered
Import ArcGIS online Feature Class to Local SDE
Question asked by jay.kapalczynski on Sep 13, 2017
Latest reply on Sep 14, 2017 by jay.kapalczynski
I have been using the below Python script for quite sometime now.  It basically grabs a feature class, attachments etc in our ArcGIS online account and pulls it down to our SDE db.
For some reason it just stopped working...I am wondering if something changed in AGO that would have caused this?
I dont know if parameters changed or something else....
I know its super long but hoping someone can shed some light on this.
# Name:        SyncSurvey
# Purpose:     Initiate
# Author:      jame6423
# Created:     15/08/2016
# Copyright:   (c) jame6423 2016
# Licence:     <your licence>
import os, tempfile, shutil
import json, re
import uuid
import datetime, time, pytz
import urllib, urllib2
import sys
import arcpy
print "Start"
arcpy.AddMessage("Start")
print "Starting"
def getToken(username=, password=None, portal_URL = 'https://www.arcgis.com'):
    '''Gets a token from ArcGIS Online/Portal with the given username/password'''
    arcpy.AddMessage('\t-Getting Token')
    print "\t-Getting Token"
    if password == None:
        password = getpass.getpass()
    parameters = urllib.urlencode({
        'username': username,
        'password': password,
        'client': 'referer',
        'referer': portal_URL,
        'expiration': 60,
        'f': 'json'
    tokenURL = '{0}/sharing/rest/generateToken?'.format(portal_URL)
    response = urllib.urlopen(tokenURL, parameters).read()
    token = json.loads(response)['token']
    return token
def getServiceDefinition(token, survey_URL):
    '''Gets the JSON representation of the service definition.'''
    response = urllib.urlopen("{0}?f=json&token={1}".format(survey_URL, token)).read()
    serviceInfo = json.loads(response)
    return serviceInfo
def getUTCTimestamp(timezone):
    '''Returns a UTC timestamp'''
    now = datetime.datetime.now()
    timeZone = pytz.timezone(timezone)
    localNow = timeZone.localize(now)
    utcNow = localNow.astimezone(pytz.utc)
    return utcNow
def createTimestampText(datetimeObj):
    '''Format a datetime for insertion using Calculate Fields'''
    outText = ""
    timeStringFormat = "%Y-%m-%d %H:%M:%S"
    outText = datetimeObj.strftime(timeStringFormat)
    return outText
def getSurveyTables(workspace, prefix=''):
    '''Return a list of the tables participating in the survey'''
    originalWorkspace = arcpy.env.workspace
    arcpy.env.workspace = workspace
    #This is used in 2 contexts:
    #Downloaded GDB - tables have no prefix
    #Enterprise GDB - prefix is added to table name
    #The full table name (i.e. GDB.SCHEMA.NAME) is returned, so prefix is in the middle
    wildcard = '*{0}*'.format(prefix) if prefix != '' else '*'
    #List the Feature Classes & Tables
    #Tables also returns Attachment tables
    featureClasses = arcpy.ListFeatureClasses(wildcard)
    tables = arcpy.ListTables(wildcard)
    #Loop through the tables, checking for:
    #1) Is this an attachment table?
    #2) Does the prefix actually match the prefix term exactly?
    allTables = featureClasses
    allTables.extend(tables)
    outTables = []
    for t in allTables:
        tableName = t.split('.')[-1]
        nameParts = tableName.split('_')
        if '__ATTACH' not in t:
            if nameParts[0] == prefix or prefix == '':
                outTables.append(t)
    arcpy.env.workspace = originalWorkspace
    return outTables
def getLastSynchronizationTime(workspace, tableList):
    '''Looks at the existing records in the SDE and returns the latest synchronization time'''
    arcpy.AddMessage('\t-Checking Last Sychronization')
    print "\t-Checking Last Sychronization"
    statTables = []
    #Dummy value to compare time
    lastSync = datetime.datetime.fromtimestamp(0)
    for table in tableList:
        #Skip if empty table (i.e., no rows)
        arcpy.AddMessage('\t\t-Checking sync on {0}'.format(table))
        print "\t\t-Checking sync on {0}".format(table)
        #Just use the last part of the table name
        tableName = table.split(".")[-1]
        rowCheck = arcpy.GetCount_management(tableName)
        rowCount = int(rowCheck.getOutput(0))
        if rowCount > 0:
            statTable = arcpy.Statistics_analysis(tableName, r'in_memory\stat_{0}'.format(tableName), "SYS_TRANSFER_DATE MAX")
            statTables.append(statTable)
    for s in statTables:
        with arcpy.da.SearchCursor(s, ['MAX_sys_transfer_date']) as rows:
            for row in rows:
                thisDate = row[0]
                if thisDate > lastSync:
                    lastSync = thisDate
    #If we get no results (i.e., no tables) return None
    if lastSync == datetime.datetime.fromtimestamp(0):
        return None
    else:
        arcpy.AddMessage('\t\t-Last Synchornized on {0}'.format(createTimestampText(lastSync)))
        print "\t\t-Last Synchornized on {0}'.format(createTimestampText(lastSync))"
        return lastSync
def getReplica(token, serviceURL, serviceInfo, now, outDir=None, outDB="outSurvey.geodatabase", lastSync=None):
    '''Downloads the full replica and then process client-side'''
    # See http://resources.arcgis.com/en/help/arcgis-rest-api/#/Create_Replica/02r3000000rp000000/
    arcpy.AddMessage('\t-Getting Replica')
    print "\t-Getting Replica"
    createReplicaURL = '{0}/createReplica/?f=json&token={1}'.format(serviceURL, token)
    replicaParameters = {
        "geometry": "-180,-90,180,90",
        "geometryType": "esriGeometryEnvelope",
        "inSR":4326,
        "transportType":"esriTransportTypeUrl",
        "returnAttachments":True,
        "returnAttachmentsDatabyURL":False,
        "async":True,
        "syncModel":"none",
        "dataFormat":"sqlite",
    if serviceInfo["syncCapabilities"]["supportsAttachmentsSyncDirection"] == True:
        replicaParameters["attachmentsSyncDirection"] = "bidirectional"
    layerList = [str(l["id"]) for l in serviceInfo["layers"]]
    tableList = [str(t["id"]) for t in serviceInfo["tables"]]
    layerList.extend(tableList)
    replicaParameters["layers"] = ", ".join(layerList)
    layerQueries = {}
    createReplReq = urllib2.urlopen(createReplicaURL, urllib.urlencode(replicaParameters))
    #This is asynchronous, so we get a jobId to check periodically for completion
    thisJob = json.loads(createReplReq.read())
    if not "statusUrl" in thisJob:
        raise Exception("invalid job: {0}".format(thisJob))
    jobUrl = thisJob["statusUrl"]
    resultUrl = ""
    #Check for a max 1000 times (10000 sec = 2hr 46 min)
    sanityCounter = 1000
    while resultUrl == "":
        checkReq = urllib2.urlopen("{0}?f=json&token={1}".format(jobUrl, token))
        statusText = checkReq.read()
        arcpy.AddMessage(statusText)
        status = json.loads(statusText)
        if "resultUrl" in status.keys():
            resultUrl = status["resultUrl"]
        if sanityCounter < 0:
            raise Exception('took too long to make replica')
        if status["status"] == "Failed" or status["status"] == "CompletedWithErrors":
            raise Exception('Create Replica Issues: {0}'.format(status["status"]))
        arcpy.AddMessage('\t\t-Check {0}: {1}'.format(str(1001-sanityCounter), status["status"]))
        sanityCounter = sanityCounter - 1
        time.sleep(10)
    #Download the sqlite .geodatabase file
    resultReq = urllib2.urlopen("{0}?token={1}".format(resultUrl, token))
    if outDir == None:
        outDir = tempfile.mkdtemp()
    outFile = os.path.join(outDir, outDB)
    with open(outFile, 'wb') as output:
        output.write(resultReq.read())
    del(output)
    #transfer from sqlite to GDB
    surveyGDB = os.path.join(outDir, 'outSurvey.gdb')
    arcpy.CopyRuntimeGdbToFileGdb_conversion(outFile, surveyGDB)
    del(outFile)
    return surveyGDB
def filterRecords(surveyGDB, now, lastSync):
    '''Filter the records to those that need to be updated'''
    #Note - This excludes new entries that are *after* the timestamp
    #       Depending on how active the survey is, there may have been new submissions
    #           after the start of the script
    #       We put in a max time to ensure consistency in operation from run to run and
    #           table to table
    arcpy.AddMessage('\t-Filtering records to new set')
    print "\t-Filtering records to new set"
    arcpy.env.workspace = surveyGDB
    nowText = createTimestampText(now)
    tableList = getSurveyTables(surveyGDB)
    dateField = arcpy.AddFieldDelimiters(surveyGDB, "CreationDate")
    excludeStatement = "CreationDate > date '{1}'".format(dateField, nowText)
    if lastSync != None:
        lastSyncText = createTimestampText(lastSync)
        excludeStatement = excludeStatement + " OR CreationDate <= date '{0}'".format(lastSyncText)
    arcpy.AddMessage('\t\t-{0}'.format(excludeStatement))
    print "\t\t-{0}'.format(excludeStatement)"
    i = 0
        i = i + 1
        thisName = 'filterView{0}'.format(str(i))
        dsc = arcpy.Describe(table)
        if dsc.datatype == u'FeatureClass' or dsc.datatype == u'FeatureLayer':
            arcpy.AddMessage('\t\t{0}'.format('featureclass'))
            print "\t\t{0}'.format('featureclass')"
            arcpy.MakeFeatureLayer_management(table, thisName, excludeStatement)
            arcpy.DeleteFeatures_management(thisName)
        else:
            arcpy.MakeTableView_management(table, thisName, excludeStatement)
            arcpy.DeleteRows_management(thisName)
        arcpy.Delete_management(thisName)
def addTimeStamp(surveyGDB, timestamp):
    '''Disables editor tracking, adds and populates the timestamp field'''
    arcpy.AddMessage('\t-Adding Syncronization Time')
    print "\t-Adding Syncronization Time"
        #Disable Editor Tracking
        arcpy.DisableEditorTracking_management(table)
        #Add a synchronization field
        arcpy.AddField_management(table, 'SYS_TRANSFER_DATE', 'DATE')
    #Set it to the timestamp
    with arcpy.da.Editor(surveyGDB) as edit:
            with arcpy.da.UpdateCursor(table, ['SYS_TRANSFER_DATE']) as rows:
                for row in rows:
                    rows.updateRow([timestamp])
    del(edit)
    return
def addKeyFields(workspace):
    '''To enable transfer of attachments with repeats, we need an additional GUID field to serve as a lookup'''
    dscW = arcpy.Describe(workspace)
    tableList = []
    relClasses = [c.name for c in dscW.children if c.datatype == u'RelationshipClass']
    for child in relClasses:
        dscRC = arcpy.Describe(child)
        if dscRC.isAttachmentRelationship:
            originTable = dscRC.originClassNames[0]
            originFieldNames = [f.name for f in arcpy.ListFields(originTable)]
            if 'rowid' not in originFieldNames:
                arcpy.AddField_management(originTable, 'rowid', 'GUID')
                with arcpy.da.Editor(workspace) as edit:
                    with arcpy.da.UpdateCursor(originTable, ['rowid']) as urows:
                        for urow in urows:
                            urow[0] = '{' + str(uuid.uuid4()) + '}'
                            urows.updateRow(urow)
                del(edit)
def createTables(surveyGDB, outWorkspace, prefix):
    '''Creates the doamins, tables and relationships of the survey in the target workspace'''
    arcpy.AddMessage('\t-Creating Tables')
    print "\t-Creating Tables"
    allTables = getSurveyTables(surveyGDB)
    dscW = arcpy.Describe(arcpy.env.workspace)
    #migrate the domains
    arcpy.AddMessage('\t\t-Creating Domains')
    print "\t\t-Creating Domains"
    for domainName in dscW.domains:
        if domainName[0:3] == 'cvd':
            arcpy.AddMessage('\t\t\t-'.format(domainName))
            print "\t\t\t-'.format(domainName)"
            tempTable = 'in_memory\{0}'.format(domainName)
            domainTable = arcpy.DomainToTable_management(surveyGDB, domainName, tempTable,'CODE', 'DESC')
            newDomain = arcpy.TableToDomain_management(tempTable, 'CODE', 'DESC', outWorkspace, domainName, update_option='REPLACE')
            arcpy.Delete_management(tempTable)
    arcpy.AddMessage("\t\t-Creating Feature Classes & Tables")
    print "\t\t-Creating Feature Classes & Tables"
    for table in allTables:
        newTableName = "{0}_{1}".format(prefix, table)
        templateTable = template=os.path.join(surveyGDB, table)
        if dsc.datatype == u'FeatureClass':
            newTable = arcpy.CreateFeatureclass_management(outWorkspace, newTableName, "POINT", template=templateTable, spatial_reference=dsc.spatialReference)
        else:
            newTable = arcpy.CreateTable_management(outWorkspace, newTableName, template=templateTable)
        arcpy.AddMessage("\t\t\t-Created {0}".format(newTableName))
        print "\t\t\t-Created {0}".format(newTableName)
        #Attach domains to fields
        tableFields = arcpy.ListFields(table)
        for field in tableFields:
            if field.domain != '':
                arcpy.AssignDomainToField_management(newTable, field.name, field.domain)
        if dscW.workspaceType == "RemoteDatabase":
            arcpy.RegisterAsVersioned_management(newTable)
    arcpy.AddMessage('\t\t-Creating Relationships')
    print "\t\t-Creating Relationships"
    #Reconnect Relationship classes, checking for attachments
    CARDINALITIES = {
    'OneToOne': "ONE_TO_ONE",
    'OneToMany': "ONE_TO_MANY",
    'ManyToMany': "MANY_TO_MANY"
    for child in [(c.name, c.datatype) for c in dscW.children if c.datatype == u'RelationshipClass']:
        dscRC = arcpy.Describe(child[0])
        RCOriginTable = dscRC.originClassNames[0]
        RCDestTable = dscRC.destinationClassNames[0]
        newOriginTable = "{0}_{1}".format(prefix, RCOriginTable)
        newOriginPath = os.path.join(outWorkspace, newOriginTable)
            #Simple case - attachments have a dedicated tool
            arcpy.EnableAttachments_management(newOriginPath)
        else:
            newDestTable = "{0}_{1}".format(prefix, RCDestTable)
            newDestPath = os.path.join(outWorkspace, newDestTable)
            newRC = os.path.join(outWorkspace, "{0}_{1}".format(prefix, child[0]))
            relationshipType = "COMPOSITE" if dscRC.isComposite else "SIMPLE"
            fwd_label = dscRC.forwardPathLabel if dscRC.forwardPathLabel != '' else 'Repeat'
            bck_label = dscRC.backwardPathLabel if dscRC.backwardPathLabel != '' else 'Main Form'
            msg_dir = dscRC.notification.upper()
            cardinality = CARDINALITIES[dscRC.cardinality]
            attributed = "ATTRIBUTED" if dscRC.isAttributed else "NONE"
            originclassKeys = dscRC.originClassKeys
            originclassKeys_dict = {}
            for key in originclassKeys:
                originclassKeys_dict[key[1]] = key[0]
            originPrimaryKey = originclassKeys_dict[u'OriginPrimary']
            originForiegnKey = originclassKeys_dict[u'OriginForeign']
            arcpy.CreateRelationshipClass_management(newOriginPath, newDestPath, newRC, relationshipType, fwd_label, bck_label, msg_dir, cardinality, attributed, originPrimaryKey, originForiegnKey)
            #Regular Relation
def getTablesWithAttachments(workspace, prefix):
    '''Lists the tables that have attachments, so that we can seperately process the attachments during migration'''
    arcpy.AddMessage('\t-Finding Attachments')
    print "\t-Finding Attachments"
    tableList = []
        dbNameParts = child.split(".")
        childParts = dbNameParts[-1].split("_")
        if childParts[0] == prefix:
                originParts = originTable.split(".")
                tableList.append(originParts[-1])
    return tableList
def createFieldMap(originTable, originFieldNames, destinationFieldNames):
    '''Matches up fields between tables, even if some minor alteration (capitalization, underscores) occured during creation'''
    arcpy.AddMessage('\t\t-Field Map')
    print "\t\t-Field Map"
    fieldMappings = arcpy.FieldMappings()
    for field in originFieldNames:
        if field != 'SHAPE':
            thisFieldMap = arcpy.FieldMap()
            thisFieldMap.addInputField(originTable, field)
            if field in destinationFieldNames:
                #Easy case- it came over w/o issue
                outField = thisFieldMap.outputField
                outField.name = field
                thisFieldMap.outputField = outField
                #arcpy.AddMessage("\t".join([field, field]))
            else:
                #Use regular expression to search case insensitve and added _ to names
                candidates = [x for i, x in enumerate(destinationFieldNames) if re.search('{0}\W*'.format(field), x, re.IGNORECASE)]
                if len(candidates) == 1:
                    outField.name = candidates[0]
            fieldMappings.addFieldMap(thisFieldMap)
    return fieldMappings
def appendTables(surveyGDB, workspace, prefix):
    '''Append the records from the survey into the destination database'''
    arcpy.AddMessage('\t-Adding records')
    print "\t-Adding records"
    attachmentList = getTablesWithAttachments(workspace, prefix)
        #Normalize table fields to get schemas in alignmnet- enable all editing, make nonrequired
        fields = arcpy.ListFields(table)
        for field in fields:
            if not field.editable:
                field.editable = True
            if field.required:
                field.required = False
        destinationName = "{0}_{1}".format(prefix, table)
        destinationFC = os.path.join(workspace, destinationName)
        arcpy.AddMessage('\t\t-{0} > {1}'.format(table, destinationName))
        print "\t\t-{0} > {1}".format(table, destinationName)
        #First, append the table
        #Match up the fields
        originFieldNames = [f.name for f in arcpy.ListFields(table)]
        destFieldNames = [f.name for f in arcpy.ListFields(destinationFC)]
        fieldMap = createFieldMap(table, originFieldNames, destFieldNames)
        arcpy.AddMessage('\t\t-{0}'.format(table))
        print "\t\t-{0}".format(table)
        arcpy.Append_management(table, destinationFC, 'NO_TEST', fieldMap)
        if destinationName in attachmentList:
            appendAttachments(table, destinationFC)
def appendAttachments(inFC, outFC, keyField='rowid', valueField = 'globalid'):
    arcpy.AddMessage('\t\t\t-Adding attachments')
    print "\t\t\t-Adding attachments"
    # 1) scan through both GlobalID and rowID of the old and new features and build a conversion dictionary
    GUIDFields = [keyField, valueField]
    inDict = {}
    outDict = {}
    lookup = {}
    inAttachTable = "{0}__ATTACH".format(inFC)
    outAttachTable = "{0}__ATTACH".format(outFC)
    with arcpy.da.SearchCursor(inFC, GUIDFields) as inputSearch:
        for row in inputSearch:
            inDict[row[0]] = row[1]
    with arcpy.da.SearchCursor(outFC, GUIDFields) as outputSearch:
        for row in outputSearch:
            outDict[row[0]] = row[1]
    for key, inValue in inDict.iteritems():
        if key not in outDict.keys():
            raise Exception('missing key: {0}'.format(key))
        lookup[inValue] = outDict[key]
    # 2) Copy the attachment table to an in-memory layer
    tempTableName = r'in_memory\AttachTemp'
    tempTable = arcpy.CopyRows_management(inAttachTable, tempTableName)
    # 3) update the attachment table with new GlobalIDs
    with arcpy.da.UpdateCursor(tempTable, ['REL_GLOBALID']) as uRows:
        for uRow in uRows:
            uRow[0] = lookup[uRow[0]]
            uRows.updateRow(uRow)
    # 4) Append to destination attachment table
    arcpy.Append_management(tempTable, outAttachTable, 'NO_TEST')
def FAIL(sectionText, err):
    #arcpy.AddMessage ('======================')
    #arcpy.AddMessage ('FAIL: {0}'.format(sectionText))
    #arcpy.AddMessage ('exception:')
    #arcpy.AddMessage (err)
    #arcpy.AddMessage (err.args)
    #arcpy.AddMessage (sys.exc_info()[0])
    #arcpy.AddMessage (sys.exc_info()[2].tb_lineno)
    #arcpy.AddMessage ('----------------------')
    #arcpy.AddMessage ('arcpy messages:')
    #arcpy.AddMessage (arcpy.GetMessages(1))
    #arcpy.AddMessage (arcpy.GetMessages(2))
    print "======================"
    print "FAIL: {0}".format(sectionText)
    print "exception:"
    print "err"
    print "err.args"
    print "sys.exc_info()[0]"
    print "sys.exc_info()[2].tb_lineno"
    print "----------------------"
    print "arcpy messages:"
    print "arcpy.GetMessages(1)"
    print "arcpy.GetMessages(2)"
    return
def cleanup(ops, sdeConnection, prefix, now):
    if 'append' in ops.keys():
        arcpy.env.workspace = sdeConnection
        nowTS = createTimestampText(now)
        i = 0
        for table in ops['append']:
            i = i + 1
            thisName = 'layerOrView{0}'.format(str(i))
            whereStatment = "sys_transfer_date = timestamp'{0}'".format(nowTS)
            selection = None
                arcpy.MakeFeatureLayer_management(table, thisName, whereStatment)
            else:
                arcpy.MakeTableView_management(table, thisName, whereStatment)
            arcpy.Delete_management(view)
    if 'createTables' in ops.keys():
        tableList = getSurveyTables(sdeConnection, prefix)
            arcpy.Delete_management(table)
#    if 'tempdir' in ops.keys():
#        shutil.rmtree(ops['tempdir'])
def ConfigSectionMap(cfg, section):
    dict1 = {}
    options = cfg.options(section)
    for option in options:
        try:
            dict1[option] = cfg.get(section, option)
            if dict1[option] == -1:
                DebugPrint("skip: %s" % option)
        except:
            print("exception on %s!" % option)
            dict1[option] = None
    return dict1
def test(section):
    import ConfigParser
    os.chdir(r'C:\Users\jame6423\Documents\Projects\SDEmigration')
    cfg = ConfigParser.ConfigParser()
    cfg.read('test.ini')
    ## Polio Test
    testConfig = ConfigSectionMap(cfg, section)
    testConfig['sde_conn'] = os.path.join(os.path.abspath(os.curdir), testConfig['sde_conn'])
    process(testConfig['sde_conn'], testConfig['prefix'], testConfig['service_url'], testConfig['username'], testConfig['password'], testConfig['timezone'])
def process(sdeConnection, prefix, featureServiceUrl, timezone, portalUrl=None, username=None, password=None):
    '''Operations:
        1) Query Feature Service endpoint for table names & IDs
        2) Check for existing tables
        3) If existing tables, get last synchronization time
        4) CreateReplica a FGDB
        5) Download the FGDB
        6) If new, create the tables
        7) Append
    now = getUTCTimestamp(timezone)
    cleanupOperations = {}
    section = 'Beginning'
    try:
        section = 'Logging in to Survey'
        tokenTest = arcpy.GetSigninToken()
        token = None
        if tokenTest == None:
            token = getToken(username, password, portalUrl)
        else:
            token = tokenTest['token']
        serviceInfo = getServiceDefinition(token, featureServiceUrl)
        if 'Sync' not in serviceInfo['capabilities']:
            arcpy.AddError('Sync Capabilities not enabled')
            raise Exception('Sync Capabilities not enabled')
        section = 'Checking Existing Data'
        existingTables = getSurveyTables(sdeConnection, prefix)
        lastSync = None
        if len(existingTables) > 0:
            lastSync = getLastSynchronizationTime(sdeConnection, existingTables)
        section = 'Downloading Survey'
        tempdir = tempfile.mkdtemp()
        #cleanupOperations['tempdir'] = tempdir
        surveyGDB = getReplica(token, featureServiceUrl, serviceInfo, now, outDir=tempdir, lastSync=lastSync)
        section = 'Preprocess Surveys for transfer'
        addTimeStamp(surveyGDB, now)
        addKeyFields(surveyGDB)
        if len(existingTables) == 0:
            section = 'Making Tables'
            createTables(surveyGDB, sdeConnection, prefix)
            cleanupOperations['createTables'] = True
        section = 'Updating Tables'
        cleanupOperations['append'] = existingTables
        appendTables(surveyGDB, sdeConnection, prefix)
        cleanupOperations.pop('append', None)
        cleanupOperations.pop('createTables', None)
    except Exception as e:
        FAIL(section, e)
    finally:
        #clean up
        cleanup(cleanupOperations, sdeConnection, prefix, now)
    return
def main():
    sde_conn = r"C:\\Users\\xxxx\\AppData\\Roaming\\ESRI\\Desktop10.4\\ArcCatalog\\xxxx@Admin.sde"
    prefix = r"BRs"
    featureService = r"https://services2.arcgis.com//xxxxxx//arcgis//rest//services//xxxxx//xxxxx//"
    timezone = r"US/Eastern"
    portal = r"https://www.arcgis.com"
    username = r"username"
    password = r"password"
    process(sde_conn, prefix, featureService, timezone, portal, username, password)
    arcpy.SetParameterAsText(7, sde_conn)
#pass
if __name__ == '__main__':
    main()
Outcomes
