Power outage break license
343
09-09-2017 11:28 PM
ModyBuchbinder
Hello
We have single use licenses on win7.
When we have power outage many times the license become un trusted and cannot be repaired.
It never happens when we shutdown the power only when their is power outage.
Some cases the license is not affected, some other time it can be repaired but many other times it just lost and need to be released by esri.
Any ideas?
JayantaPoddar
MVP Esteemed Contributor
If you know the Authorization code used in each machine, you could clear the trusted storage, and reauthorize the SU license.
But an important thing to do is to connect all the machines to UPS.
Think Location
ModyBuchbinder
Hi Jayanta
Thanks but as far as I understand if you registered the license once it is written as used in MyEsri and can not be registered again even from the same machine.
JayantaPoddar
It can be registered in the same machine only, without a reset. This can be done a few times in the same machine. Try it, and let me know.
Think Location
