I referred to the following article in trying to resolve the black image issue.
http://support.esri.com/en/technical-article/000008395
I ran the Calculate Statistics tool and didn't receive an error yet the stats was not updated.
I created a tif from a mosaic raster that didn't have stats also, I don't know if this is an contributing factor.
Lastly, MUST I have the stats calculated to display a raster imagery properly ?
even with statistics, this might be just an issue with the stretching you use. Go to the display properties and try "percent clip" first - that is a likely setting to solve it. Look at the statistics and analyze them.
Regards Guenter
I already have the Stretch set to Percent Clip
The statistics are uncalculated and can't be calculated.
Thank you for the suggestions though.
