Is there a way to suppress the page number in the Story Map Series. We are using single page ones to embed in websites since embedding the basic one is not currently available. It works fairly well but the page number shows up at the bottomat the bottom which makes no sense. For example:
Curbside Collection - City of Kitchener
Road Closures - City of Kitchener
Solved! Go to Solution.
Yes, in the Story Map Series Builder, go to Settings and switch the layout you are using from Bulleted to Tabbed. In a tabbed Story Map Series, the tabs aren't numbered. In a bulleted Story Map Series the bullets are always numbered, and you can't turn numbers off for the bullets. Alternatively you could use the Side Accordion layout for your Story Map Series, and turn numbering off. In a side accordion Story Map Series, the sections are numbered by default but you can turn numbering off in a side accordion via the check box in the Settings > Layout Options tab.
Rupert
Rupert
