401 Unauthorized - Conda install of arcgis
1394
09-05-2017 04:51 PM
PhilLarkin1
Occasional Contributor III
I had previously upgraded the arcgis package to 1.0.1. When I attempted to upgrade to 1.2.3 I received the error below. Has anyone else experienced this?
Fetching package metadata .........Warning: you may need to login to anaconda.org again with 'anaconda login' to access private packages(https://conda.anaconda.org/t/<TOKEN>/esri/win-64/, 401 Client Error: UNAUTHORIZED forurl: https://conda.anaconda.org/t/None/esri/win-64/repodata.json)Warning: you may need to login to anaconda.org again with 'anaconda login' to access private packages(https://conda.anaconda.org/t/<TOKEN>/esri/noarch/, 401 Client Error: UNAUTHORIZED for url: https://conda.anaconda.org/t/None/esri/noarch/repodata.json)....
-On Proceed Step-
Fetching packages ...
Error: HTTPError: 401 Client Error: UNAUTHORIZED for url: https://conda.anaconda.org/t/None/esri/win-64/arcgis-1.2.3-py35_1.tar.bz2: https://conda.anaconda.org/t/None/esri/win-64/arcgis-1.2.3-py35_1.tar.bz2
PhilLarkin1
Thanks for your reply Dan Patterson
The problem probably originated from the fact that I was trying to upgrade a package in an environment, and I think the environment was a manual copy of Pro's conda environment ('arcgispro-py3'). There might be a license validation step that appends a token to the upgrade request in conda.
To fix this I upgraded ArcGIS from Pro, and then manually copied the environment folder from C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3 to my env location and renamed. This is awfully hacky, but it doesn't appear that cloning pro's environment is supported. (see post:https://community.esri.com/thread/196691-create-cloned-conda-environment-as-user#comment-694016)
DanPatterson_Retired
Just did it... worked for me... did you use proenv.bat from within your conda path?
mine is
C:\ArcPro\bin\Python\Scripts\proenv.bat
yours will probably differ up to the bin folder
YourDrive:\YourPathToArcGISPro\ bin\Python\Scripts\proenv.bat
PhilLarkin1
As Clinton points out in that thread, perhaps in the future it will be easier
