I have created a nmf file in Arcgis explorer. Now when i have trying to open the same file in Arcgis explorer, that was not opened and says...problem with contents Arcgis explorer. Plz solve my problem as it was very important for me.
Solved! Go to Solution.
the file only references data and its path... it if doesn't work in another installation, then you will have to revisit how you created it and whether or not the data are available to others.
Thanks a lot... Sir...
