AnsweredAssumed Answered
Qml - load a tif map and use it offline, without any online base map?
Question asked by anat@skysoftsl.com on Sep 3, 2017
Latest reply on Sep 5, 2017 by anat@skysoftsl.com
Hi, I have a tif (and tfw) map that I want to be able to use offline (QML).
I have managed to load the tif as a raster layer on top of an online map, but I want to avoid it.
I I try to remove the BasemapImagery {}, the raster doesn't load...
In addition, how do I load the tfw file?
This is my code:
ApplicationWindow {
      width: 850
      height: 650
      title: "MapsProj"
      Rectangle {
           clip: true
           width: 800
           height: 600
           property real scaleFactor: System.displayScaleFactor
           property var rasterLayer: null
           property string rasterFilePath: "file:///C:/Projects/Sample/Maps/map1.tif"
           MapView {
                anchors.fill: parent
                Map {
                    BasemapImagery {}
                    RasterLayer {
                           Raster {
                                 path: ""
                    onLoadStatusChanged: {
                           if (loadStatus !== Enums.LoadStatusLoaded)
                                    return;
                            mapView.setViewpointCenterAndScale(fullExtent.center, 80000);
     Rectangle {
          visible: addButton.visible
           anchors.centerIn: addButton
           radius: 8 * rootRectangle.scaleFactor
           height: addButton.height + (16 * rootRectangle.scaleFactor)
           width: addButton.width + (16 * rootRectangle.scaleFactor)
           color: "lightgrey"
           border.color: "darkgrey"
           border.width: 2 * rootRectangle.scaleFactor
           opacity: 0.75
     Button {
           anchors {
                   bottom: parent.bottom
                   horizontalCenter: parent.horizontalCenter
                   margins: 32 * rootRectangle.scaleFactor
           text: "Add Raster"
           onClicked: {
                 rootRectangle.createAndAddRasterLayer(rootRectangle.rasterFilePath)
      function createAndAddRasterLayer(rasterUrl) {
          var newRaster = ArcGISRuntimeEnvironment.createObject("Raster", {path: rasterUrl});
          rasterLayer = ArcGISRuntimeEnvironment.createObject("RasterLayer", {raster: newRaster});
          rasterLayer.loadStatusChanged.connect(zoomToRaster);
          map.operationalLayers.clear();
          map.operationalLayers.append(rasterLayer);
     function zoomToRaster(){
        if (rasterLayer === null)
              return;
        if (rasterLayer.loadStatus !== Enums.LoadStatusLoaded)
              return;
         mapView.setViewpointCenterAndScale(rasterLayer.fullExtent.center, 80000);
Outcomes
