saving details of a grid to apply to other files
2140
18
08-31-2017 11:13 AM
HelgaGomes
My apologies if this is a super easy question or has been asked before but I cant seem to find it because my ArcMap expertise is severely limited.When we produce maps as figures for publication we set a grid using View->Data Frame Properties->New Grid and chose out of the 3 options - usually "Graticule divides map by Meridians and Parallels as it suits our oceanographic setup. Then we go through all the details like font, line style etc all of which can get tedious if you have many figures and have to repeat this again and again. How can we save a template like file of our setup and apply it to all our other figures in the future? That would save us a ton of time! Thanks a lot!
Helga
JayantaPoddar
MVP Esteemed Contributor
It would have been more helpful if you could have attached screenshots of your MXDs/ Table of Content.
Every MXD will have at-least 1 Data Frame. By default, the name of the Data Frame is "Layers". I had just renamed my Data Frame to "Template Data Frame".
Using data frames—Help | ArcGIS for Desktop
Think Location
JayantaPoddar
Hi Helga,
After you make the necessary changes to create a custom Map Document, save the map in
C:\Users\<UserName>\AppData\Roaming\ESRI\Desktop10.x\ArcMap\Templates
This template will show up every time you open a new document in ArcMap, alongside the Blank Map.
Also keep a backup of this map document, as the template could get deleted if the C: Drive is formatted or if the ArcGIS Profile is reset.
Think Location
HelgaGomes
Thanks a lot Jayanta. before anything else I tried to locate this Templates folder in my ArcMap but i couldnt find it.
Can i/Should I make one?
HelgaGomes
Sorry Jayanta I did find the folder.
So now do I just do File-> Save as->MyTemplate
and then when I want to use it for another file how do I get MyTemplate back?
Thanks a lot.
Helga
JayantaPoddar
When you use the template for another file and click SAVE button, it will prompt you to save the file as a different name (SAVE AS option). So the template file which you have just created cannot be overwritten.
Save the other finished MXDs to your project folder.
Think Location
JayantaPoddar
Navigate to C:\Users\<CurrentUserName>\AppData\Roaming.
If the AppData Folder is hidden, check Show Hidden Files and Folders
The complete path is C:\Users\<UserName>\AppData\Roaming\ESRI\Desktop10.x\ArcMap\Templates
Think Location
HelgaGomes
To clarify I already have made my maps for a dataset X and now I would like to reproduce the exact grid with all the details that my colleague produced from her files to mine so we have the same identical grids as the region is the same.
HelgaGomes
Hi Jayanta,
Thanks a million. Yes after using the "Show Hidden Files" i was able to navigate to C:\Users\helga\AppData\Roaming\ESRI\Desktop10.4\ArcMap
1)Then I took my colleague's file which has the correct grid and Save as into the above location and named it XXYY
2) Now i am still confused as to how to apply this XXYY template to my own files.Sorry!
JayantaPoddar
There is nothing to be sorry about.
Do you have any MXD which has the desired template? If yes, then open the MXD file > Remove all the layers from the Table of Contents. You should still see the Grids and Graticules in it since it is a property of the Data Frame. Save this MXD to the C:\Users\<UserName>\AppData\Roaming\ESRI\Desktop10.x\ArcMap\Templates.
Optional
If you also want to preserve the symbology of the layers, then you need to save the layers in Table of Contents as Layer Files (.lyr). Then you can import the symbology of the saved layer files to your layers.
I feel that I didn't understand your requirement properly.
Could you explain your requirement further with appropriate screenshots?
Think Location
HelgaGomes
Hi Jayant,
Thanks ever so much. I think i understood it partially. 1) So in order to make my Template I take the MXD file that has all the settings that I want, then I remove all the layers 2) I Save As -> MyTemplate in C:\Users\helga\AppData\Roaming\ESRI\Desktop10.4\ArcMap\Templates 3) I then use this MyTemplate file to "Add" my project data and make a new MXD file. This will now have the grid from my template.
BUT NOW MY QUESTION IS:
What if I already have a MXD file which has no grid but I want to import the grid from MyTemplate into it. Can this not be done?
Do I have to start with MYTemplate and then add layers to it?
