Hi!
I am using C++/Qt template for ArcGIS Runtime 100.1 and am trying to use the GeometryEngine::ellipseGeodesic method and it seems that the only way to do that is by passing in an instance of the GeodesicEllipseParameters class.
However, my issue is that when I try to include the header file for the parameters class (#include <GeodesicEllipseParameters>) the compiler tells me the file is not included.
Is there a different name for the class or another way to use the ellipseGeodesic method? I got this header file from the C++ API so I can't imagine it being incorrect, every other class has worked so far for me.
Thanks!
Solved! Go to Solution.
Hi Nicholas, thanks for getting in touch. The GeodesicEllipseParameters class is actually defined in the header of GeometryEngine.h (along with a number of other types used by this class). If you are already including GeometryEngine you should be able to remove the line "#include <GeodesicEllipseParameters>" and it ought to work. Please let me know if you have any issues.
Luke
Luke
Thank you, that worked!
