I am having a problem configuring the Chart Widget. I am only getting one option for “Chart Display” when I used to have 4 namely:
Display values feature by feature
Display values by category
Display feature counts by category
Display attribute values as charts
I am now only getting the 3rd option only. Display feature counts by category. How do I get the others to show?
Regards
Tankiso
Solved! Go to Solution.
Hi Tankiso, you may want to test you field type - are you using string or integer? This may affected how you will be able to chart your data.
Thanks Alix,
After changing field type to integer it worked like a charm
Regards
Tankiso
