Hi All,
Struggling trying to parse selected attribute to a table DIV . Tried to create tabledivas seen below. Sample code is from this link https://developers.arcgis.com/javascript/latest/sample-code/popup-custom-action/index.html
Solved! Go to Solution.
Henry,
See if this works for what you are after:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Custom popup actions per feature attribute - 4.4</title>
<style>
body {
font-family: sans-serif;
padding: 0;
margin: 0;
height: 100%;
width: 100%;
overflow: hidden;
#viewDiv {
position: absolute;
right: 300px;
left: 0;
top: 0;
bottom: 0;
#tblDiv {
position: absolute;
right: 0px;
top: 0;
bottom: 0;
width: 300px;
overflow: auto;
border-collapse: collapse;
#tblDiv thead tr {
background-color: #4CAF50;
color: white;
#tblDiv tr:nth-child(even) {
background-color: #f2f2f2;
#tblDiv th, td {
border: 1px solid #ddd;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.4/esri/css/main.css">
<script src="https://js.arcgis.com/4.4/"></script>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"dojo/domReady!"
], function(
Map, MapView, FeatureLayer
var map = new Map({
basemap: "streets-navigation-vector"
var view = new MapView({
container: "viewDiv",
map: map,
center: [0.46564130, 51.736810],
zoom: 17
* Add feature layer
// sampling of breweries
var featureLayer = new FeatureLayer({
url: "https://services7.arcgis.com/uE69mPI6U3rpSmCT/arcgis/rest/services/AddressA_csv/FeatureServer/0",
outFields: ["*"],
//definitionExpression: "country = 'United States'",
// add a custom action
popupTemplate: {
title: "{Postcode}",
content: [{
type: "fields",
fieldInfos: [{
fieldName: "Postcode"
actions: [{
image: "beer.png",
title: "Brewery Info"
map.add(featureLayer);
function showResults(response) {
var tbl = document.getElementById("tblDiv");
//clear the table
tbl.innerHTML = "";
var header = tbl.createTHead();
var headerRow = header.insertRow(0);
var headerCell = headerRow.insertCell(0);
headerCell.innerHTML = "Name";
var headerCell2 = headerRow.insertCell(1);
headerCell2.innerHTML = "Value";
var tblBody = document.createElement('tbody');
tbl.appendChild(tblBody);
var tableRef = tbl.getElementsByTagName('tbody')[0];
var popup = view.popup;
var atts = popup.viewModel.selectedFeature.attributes;
var row, cell, cell2;
for (var key in atts) {
if (atts.hasOwnProperty(key)) {
row = tableRef.insertRow(0);
cell = row.insertCell(0);
cell2 = row.insertCell(1);
cell.innerHTML = key;
cell2.innerHTML = atts[key];
view.then(function() {
popup.viewModel.on("trigger-action", function(event) {
if (event.action.id === "find-brewery") {
showResults();
</script>
</head>
<body class="light">
<div id="viewDiv"></div>
<table id="tblDiv"></table>
</body>
</html>
Henry,
<!DOCTYPE html>
<html>
<head>
<style>
body {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
overflow: hidden;
#viewDiv {
position: absolute;
right: 300px;
left: 0;
top: 0;
bottom: 0;
#tblDiv {
position: absolute;
right: 0px;
top: 0;
bottom: 0;
width: 300px;
overflow: auto;
#tblDiv thead tr {
color: white;
#tblDiv th, td {
</style>
<script>
require([
"esri/Map",
"dojo/domReady!"
], function(
var map = new Map({
map: map,
zoom: 17
* Add feature layer
outFields: ["*"],
popupTemplate: {
content: [{
type: "fields",
fieldInfos: [{
actions: [{
image: "beer.png",
//clear the table
tbl.innerHTML = "";
showResults();
</script>
</head>
</body>
</html>
Thanks Robert Sche. it works. Thank you!
