Attribute Expressions in Popups Using Arcade - Wildcard?
2170
08-11-2017 09:47 AM
by Anonymous User
Not applicable
Is it possible to use wildcards in Arcade?
I am creating an attribute expressions where i have an IIF statement.
IIF(Field1="Landowner" || Field1=" Landowner 1+ pref"), "True", "False")
Would it be possible to wildcard landowner so it picked up everything with Landowner as the value instead of creating a bunch of OR statements?
MatthewLofgren
This doesn't answer your question about wildcards, but for this example you could do
IIF(Find("Landowner", Field1) >= 0), "True", "False")
which will search Field1 for the word "Landowner" and return it's position. If the position returned is >=0, Field1 contains the word "Landowner".
MatthewLofgren
KenBuja
MVP Esteemed Contributor
You can use the Find expression to look for that term.
IIF(Find("Landowner", $feature.Field1) > -1, "True", "False");‍
Edit...
matt2222‌ beat me to the answer
