Reclass Field Calculator problem
1573
08-10-2017 02:49 AM
MartaPo
I am having a massive problem with running this script in ArcGIS 10.3 Field Calculator Python
def Reclass(CLASS):
 if CLASS=="2":
  return "2a"
 elif CLASS=="3"
  return "3a"
 else:
  return (CLASS)
Any help much appreciated.
Thank you,
Marta
Tags (1)
XanderBakker
Esri Esteemed Contributor
Try this:
def Reclass(CLASS):
  if CLASS=="2":
    return "2a"
  elif CLASS=="3":
    return "3a"
  else:
    return CLASS
XanderBakker
Try this:
def Reclass(CLASS):
  if CLASS=="2":
    return "2a"
  elif CLASS=="3":
    return "3a"
  else:
    return CLASS
MartaPo
Hi Xander,
It is working now. I have not realised that the spacing is so important. Thank you
XanderBakker
You are welcome, glad it works
JoshuaBixby
MVP Esteemed Contributor
If Xander's suggestion doesn't work, it would be helpful if you explain what exactly isn't working, including posting the error message(s).
