I'm trying to implement Esri's public facing outage map. Where can I find documentation to help guide me through the process? I'm using Schneider Electric's Responder for an Outage Management System and would like to use the data generated from it to create the map.
Solved! Go to Solution.
Hi JW,
Here's a link to the solution app page: Public Outage Map | ArcGIS for Electric
And here's the Get Started documentation: Overview - Public Outage Map | ArcGIS for Electric
Hope this helps,
Hi JW,
Hope this helps,
J.W., were you able to find any additional ArcFM/Responder specific information on their Outage Map? I'm working on the same issue now. Trying to understand what layers/data sources to link into which of the predefined layers for the Outage service configuration.
Mike.
