AnsweredAssumed Answered
Update control on DockPane
Question asked by bulla_b on Aug 4, 2017
Latest reply on Aug 8, 2017 by bulla_b
Following the BingStreetside sample on GitHub, I have created a MapTool and a DockPane.  On the DockPaneI have a WebBroswer control that I want to update when I click on the map with the MapTool.  I am having troubles referencing the DockPanel from the MapTools click event.
Here is a snippet of the Dockpane.xaml for the WebBrowser:
<Grid Margin="0">
<WebBrowser x:Name="streetViewControl" Margin="0" />
</Grid>
Here is the code I am using in Dockpane.xaml.cs:
namespace StreetView_ArcPro
/// <summary>
/// Interaction logic for DockpaneView.xaml
/// </summary>
public partial class DockpaneView : UserControl //public partial
public DockpaneView()
InitializeComponent();
streetViewControl.Navigated += StreetViewControl_Navigated;
streetViewControl.Navigate("http://maps.google.ca");
public void SetMapLocation(double lng, double lat)
streetViewControl.Navigate(@"http://maps.google.ca/maps?q=" + lat + "," + lng + "&num1&s11=" + lat + "," + lng + "&sspn=16.71875,56.536561&ie=UTF8&ll=" + lat + "," + lng + "&spn=0.020401,0.028753&z=15&layer=c&cbll=" + lat + "," + lng + "&panoid=&cbp=12,161.92,,0,5");
private void StreetViewControl_Navigated(object sender, NavigationEventArgs e)
MessageBox.Show("Navigated");
And here is the code for the MapTool.  See comments for where I am running into problems:
public class StreetView_Tool : MapTool
public StreetView_Tool()
IsSketchTool = true;
SketchType = SketchGeometryType.Point;
SketchOutputMode = SketchOutputMode.Map;
protected override Task OnToolActivateAsync(bool active)
return base.OnToolActivateAsync(active);
protected override Task<bool> OnSketchCompleteAsync(Geometry geometry)
double lat;
double lng;
var coord = GeometryEngine.Instance.Project(geometry, SpatialReferences.WGS84) as MapPoint;
if (coord != null)
lng = coord.X;
lat = coord.Y;
//**********This is where I want to call the SetMapLocation on the DockPane, but I have no idea how to do it***********
//**********This next two line do not give me errors, but it just doesn't work.*******
var sample = new DockpaneView();
sample.SetMapLocation(lng, lat);
var ret = QueuedTask.Run(() =>
return true;
return ret;
//return base.OnSketchCompleteAsync(geometry);
Any assistance is appreciated.
Thanks!
Outcomes
