AnsweredAssumed Answered
Read folder paths out of text file and project the shapefiles
Question asked by JB1234510 on Jul 31, 2017
Latest reply on Aug 1, 2017 by JB1234510
The following python code should read out of a text file folder paths and project the shapefiles in this folder. Unfortunately this works only with the last (folder) line? Any suggestions why this doesn't work?
# Import arcpy module
import arcpy, os
fname = r"H:\python_scripte\ProjizierenMulti\test.txt"
with open(fname) as f:
    for line in f:
        print line
        arcpy.env.workspace = line
        workspace = arcpy.env.workspace
        # Use the ListFeatureClasses function to return a list of
        #  shapefiles.
        featureclasses = arcpy.ListFeatureClasses()
        # Copy shapefiles to a file geodatabase
        for fc in featureclasses:
            print "Projiziere " + fc
            outfile = os.path.splitext(fc)[0] + "_E.shp"
            spatialRef = arcpy.Describe(fc).spatialReference
            print spatialRef.name
            Ftype = arcpy.Describe(fc).datatype
            print Ftype
            if Ftype == "ShapeFile":
                if spatialRef.name == "DHDN_3_Degree_Gauss_Zone_3":
                    arcpy.Project_management(fc, outfile, "PROJCS['ETRS_1989_UTM_Zone_32N_8stellen',GEOGCS['GCS_ETRS_1989',DATUM['D_ETRS_1989',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',32500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',9.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]]", "DHDN_To_ETRS_1989_3", "PROJCS['DHDN_3_Degree_Gauss_Zone_3',GEOGCS['GCS_Deutsches_Hauptdreiecksnetz',DATUM['D_Deutsches_Hauptdreiecksnetz',SPHEROID['Bessel_1841',6377397.155,299.1528128]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Gauss_Kruger'],PARAMETER['False_Easting',3500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',9.0],PARAMETER['Scale_Factor',1.0],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]]")
f.close()
Outcomes
