Site Map not adhering to Default Map settings in Connect form
602
07-31-2017 07:20 AM
CarlHolt1
Occasional Contributor III
Configured the detailed map settings; Home Location and Zoom Level.
Default Map Settings
But when I view the Site Map for Individual results in Suvery123 for ArcGIS website it zooms on San Francisco
Individual Results of survey
ZhifangWang
Hi Carl,
Thanks for your detailed feedback.
After creating a simple survey that uses the same default home location as in your screenshot, I can reproduce the "San Fransisco" issue. However, can you please confirm it's the same issue you've seen as below?
  1. Open the Data page of the survey
  2. Refresh the page. Ensure the issue will not affect by other operations
  3. Click a feature that located near in Atlanta. (This should be the first feature you clicked in the table)
  4. The map will show location around San Fransisco
  5. Click any other feature, the map will center at the correct feature location now
    1. However, the zoom level is not correct (just much smaller) as set in Survey123 Connect
CarlHolt1
That is correct.
JamesTedrick
Esri Esteemed Contributor
Hi Carl,
This is a known issue with eh Survey123 website; we've been made more aware of it through the use of the custom print templates.  We'll be working to address this issue.
ZhifangWang
Carl,
Thanks for the confirmation, the issue has been addressed and will be fixed in 2.4 release.
