Hello, I am trying to use the Route_World service but I am not able to get my credentials in the RouteTask I believe.
My code is below, I have tried to use UserCredential to bind with the task. I have not entered my temporary token anywhere? Can anyone help me to setup? Thanks
public void setupRouteTask() { mRouteTask = new RouteTask(getApplicationContext(), routeTaskURL); UserCredential userCredential = new UserCredential(getApplicationContext().getResources().getString(R.string.arcgis_username), getApplicationContext().getResources().getString(R.string.arcgis_password)); mRouteTask.setCredential(userCredential); System.out.println(userCredential.); final ListenableFuture<RouteParameters> listenableFuture = mRouteTask.createDefaultParametersAsync(); listenableFuture.addDoneListener(new Runnable() { @Override public void run() { try { if (listenableFuture.isDone()) { int i = 0; mRouteParams = listenableFuture.get(); // create stops Stop stop1 = new Stop(new Point(28.973663, 41.014551, SpatialReferences.getWgs84())); Stop stop2 = new Stop(new Point(28.968492, 41.017619, SpatialReferences.getWgs84())); List<Stop> routeStops = new ArrayList<>(); // add stops routeStops.add(stop1); routeStops.add(stop2); mRouteParams.setStops(routeStops); // set return directions as true to return turn-by-turn directions in the result of getDirectionManeuvers(). mRouteParams.setReturnDirections(true); // solve RouteResult result = mRouteTask.solveRouteAsync(mRouteParams).get(); final List routes = result.getRoutes(); mRoute = (Route) routes.get(0); // create a mRouteSymbol graphic Graphic routeGraphic = new Graphic(mRoute.getRouteGeometry(), mRouteSymbol); // add mRouteSymbol graphic to the map mGraphicsOverlay.getGraphics().add(routeGraphic); // get directions // NOTE: to get turn-by-turn directions Route Parameters should set returnDirection flag as true final List<DirectionManeuver> directions = mRoute.getDirectionManeuvers(); String[] directionsArray = new String[directions.size()]; for (DirectionManeuver dm : directions) { directionsArray[i++] = dm.getDirectionText(); } System.out.println("route: " + directionsArray.toString()); } } catch (Exception e) { Log.e("xd", e.getMessage()); } } }); }
I would try calling mRouteTask.loadAsync() after setting your credentials. I believe this should go out and fetch an updated token for you to finish execution. Additionally, I have a feeling that credentials are case sensitive. Can you match your username to how it appears in portal / arcgis online?
