Declaring the "esri/dijit/FeatureTable" causes problems. Is there a sample set that shows how to implement in 4.3??
Solved! Go to Solution.
There is no feature table in 4.XX (yet). Also, the 4.XX API uses "widgets" in place of "dijits."
What version are you using? If you are using 3.x the following link has all the samples related to feature table-
And if you ever have a question whether 3.x functionality is available in 4.x, refer to this table:
Got it...
