HTTP Error 500 when connecting to portal
2880
07-18-2017 02:47 PM
ChristopherClary1
I am able to connect to ArcGIS online, but when we try to connect directly to our portal we receive the following error information. I am new to administering portal and not sure what i could be missing.
from arcgis.gis import GIS
gis = GIS("https://portal.organizationname.gov/mapsrus/", "username", "password")
HTTPError                                 Traceback (most recent call last)
<ipython-input-14-297762dcb9de> in <module>()
      1 from arcgis.gis import GIS
----> 2 gis = GIS("https://portal.organizationname.gov/mapsrus/", "username")
C:\Users\username\AppData\Local\Continuum\Anaconda3\lib\site-packages\arcgis\gis\__init__.py in __init__(self, url, username, password, key_file, cert_file, verify_cert, set_active, client_id, profile)
    144         self._datastores_list = None
    145         self._portal = portalpy.Portal(self._url, self._username, self._password, self._key_file, self._cert_file,
--> 146                                        verify_cert=self._verify_cert, client_id=self._client_id)
    147         if url.lower().find("www.arcgis.com") > -1 and \
    148            self._portal.is_logged_in:
C:\Users\username\AppData\Local\Continuum\Anaconda3\lib\site-packages\arcgis\_impl\portalpy.py in __init__(self, url, username, password, key_file, cert_file, expiration, referer, proxy_host, proxy_port, connection, workdir, tokenurl, verify_cert, client_id)
    161                                              proxy_port=proxy_port,
    162                                              verify_cert=verify_cert,
--> 163                                              client_id=client_id)
    164         #self.get_version(True)
    165         self.get_properties(True)
C:\Users\username\AppData\Local\Continuum\Anaconda3\lib\site-packages\arcgis\_impl\connection.py in __init__(self, baseurl, tokenurl, username, password, key_file, cert_file, expiration, all_ssl, referer, proxy_host, proxy_port, connection, verify_cert, client_id)
    279
    280         if cert_file is None and key_file is None:
--> 281             self.login(username, password, expiration, client_id)
    282
    283     #----------------------------------------------------------------------
C:\Users\username\AppData\Local\Continuum\Anaconda3\lib\site-packages\arcgis\_impl\connection.py in login(self, username, password, expiration, client_id)
    505                     self._token = newtoken
    506
--> 507             resp = self.post('', { 'f': 'json' }, add_token=False) # probe portal to find auth scheme
    508                                                   # if basic, digest, NTLM or Kerberos, etc is being used
    509                                                   # except handler will catch it and set self._auth appropriately
C:\Users\username\AppData\Local\Continuum\Anaconda3\lib\site-packages\arcgis\_impl\connection.py in post(self, path, postdata, files, ssl, compress, is_retry, use_ordered_dict, add_token, verify_cert, token, try_json, out_folder, file_name, force_bytes, add_headers)
   1036             opener.addheaders = headers
   1037             #print("***"+url)
-> 1038             resp = opener.open(url, data=encoded_postdata.encode())
   1039             resp_data, is_file = self._process_response(resp,
   1040                                                out_folder=out_folder,
C:\Users\username\AppData\Local\Continuum\Anaconda3\lib\urllib\request.py in open(self, fullurl, data, timeout)
    530         for processor in self.process_response.get(protocol, []):
    531             meth = getattr(processor, meth_name)
--> 532             response = meth(req, response)
    533
    534         return response
C:\Users\username\AppData\Local\Continuum\Anaconda3\lib\urllib\request.py in http_response(self, request, response)
    640         if not (200 <= code < 300):
    641             response = self.parent.error(
--> 642                 'http', request, response, code, msg, hdrs)
    643
    644         return response
C:\Users\username\AppData\Local\Continuum\Anaconda3\lib\urllib\request.py in error(self, proto, *args)
    568         if http_err:
    569             args = (dict, 'default', 'http_error_default') + orig_args
--> 570             return self._call_chain(*args)
    571
    572 # XXX probably also want an abstract factory that knows when it makes
C:\Users\username\AppData\Local\Continuum\Anaconda3\lib\urllib\request.py in _call_chain(self, chain, kind, meth_name, *args)
    502         for handler in handlers:
    503             func = getattr(handler, meth_name)
--> 504             result = func(*args)
    505             if result is not None:
    506                 return result
C:\Users\username\AppData\Local\Continuum\Anaconda3\lib\urllib\request.py in http_error_default(self, req, fp, code, msg, hdrs)
    648 class HTTPDefaultErrorHandler(BaseHandler):
    649     def http_error_default(self, req, fp, code, msg, hdrs):
--> 650         raise HTTPError(req.full_url, code, msg, hdrs, fp)
    651
    652 class HTTPRedirectHandler(BaseHandler):
HTTPError: HTTP Error 500: Internal Server Error
ahmed_hussiney
Hello  Christopher Clary,
I had the same issue before when connecting to my local portal and the issue was that my portal dosn't have a trusted ceritifcate installed , and to be able to connect through the API I just made set the verify certificate paramter to false and I was able to connect.
So you either need to install a certificate from trusted authority or you can escap certficate validation while connect to your portal by modify your code as the following:
gis = GIS("https://portal.organizationname.gov/mapsrus/", "username", "password",verify_cert=False)
