change number format in Attribute table widget code
672
07-18-2017 01:30 PM
NadiaTargulian
Junshan Liu
Hi Junshan,
I was wondering if it is possible to change number format in Attribute table widget code ( I need to format a number with 2 digits after the decimal point)   I think I need to change code here:
getFormattedNumber: function(num, format)   in the utils.js but not sure it is a right place. Could you point me in the right direction?
Thank you.
using WAB Dev 2.4
NadiaTargulian
I actually figured it out.
 It involves changing a number of places after decimal point in jimu.js/utils.js
I changed places: p to places: 2 in this function:
mo.localizeNumberByFieldInfo = function(n, fieldInfo) {
    var fn = null;
    var p = lang.exists('format.places', fieldInfo) && fieldInfo.format.places;
    fn = mo.localizeNumber(n, {
      places: 2
    if (lang.exists('format.digitSeparator', fieldInfo) && !fieldInfo.format.digitSeparator) {
      return fn.toString().replace(new RegExp('\\' + nlsBundle.group, "g"), "");
    } else {
      return fn;
Hope it will help someone who had the same issue!
