Using Magnify in SketchEditior
520
07-18-2017 04:24 PM
SandeepKumar5
I am using ArcGIS Runtime for iOS 100.0 and trying to use AGSSketchEditor() to create a Polyline sketch. I was wondering, is it possible to use Magnifier also while adding a vertex like in the Collector application? In sample application although the magnifier is shown but it doesn't add vertex .
I tried subscribing to the  didEndLongPressAtScreenPoint event but for it to work , need the selected vertex of sketch on map to update the sketch geometry.
by-
var geo = self.sketchEditorForEditing.geometry. as? AGSPolyline;
 self.sketchEditorForEditing.replaceGeometry(((geo?.toBuilder())?.add(mapPoint).toGeometry())!);
I wanted to know, is there a way we can get/set the selected vertex of sketch geometry being drawn on map or any other way to get this working. Thanks in advance!
MarkDostal
Thank you for your question.  There is no current way to get the magnifier to show when adding a new vertex.  However, if you tap to add a new vertex, then tap and hold on the new vertex, the magnifier will show and you can reposition the vertex.  Adding a new vertex using the magnifier is something that we are considering for the next release.
Currently there is no public API to get the selected vertex of a sketch.  Aside from needing the selected vertex for the workaround you mention above, is there a use case for you needing to get the selected vertex?  If so, that is also something we could consider.
Mark
