Mandatory question existing but not for App
695
07-14-2017 08:01 AM
SMauri
Occasional Contributor III
I made a Survey based on a feature service for verifing a set of assets inspected earlier.
The first question is about time of inspection and in "calculation" filed I use "today()" formulas for insert automatically a value based on ispection date as expected. Apparently it seems that everything works properly.
as you can see
screenshot when you can see date updated
But if I press validation button, it seems as the value is not properly inserted.
And then if I cancel value inserted by formulas with X button and hit refresh button for an updated value (obviously same value you see in this sample), then validation is successfull.
This is not the first time I create a Survey, but this is the first time that I'm trying to update a status of an existing object.
Any idea?
JohnathanHasthorpe
Hi Stefano
I can confirm that using today() in a calculation in combination with required should work. Are you able to share your survey and also let me know what operating system you are running the app on?
John
SMauri
Hi Johnathan, thank's for the answer.
Sure I can share my work with you. But I can't find your profile if I insert Johnathan in search area of my Group.
I insert my Excel file as attachment, but tell me what I can do for make easy your verify.
Survey123 is running on a smartphone with Android 7.1
Stefano
JohnathanHasthorpe
Hi Stefano - just to follow up on this. I was not able to replicate the behaviour with you survey running on my Android 7.1 device. Are you still experiencing the problem on the latest version of Survey123  (2.3)?
SMauri
Hi Johnathan, not yet tested on new version 2.3...I'll try as soon as possible.
Thank you
