arcpy.SearchCursor - features orders mixed up in Oracle enterprise geodabase
587
07-14-2017 10:33 AM
MaximeDemers
Occasional Contributor III
Something very weird happen when I use a SearchCursor over a feature class in an Oracle Enterprise Geodatabase
The order of the features in the SeachCursors changes depending of the field_names parameter that is used.
For instance:
source = "\\\\cnatrtd8\\geo\\ArcGIS Server\\Connections\\GEODEV011.sde\\GEO09E01_CS_FRA_GEN"
with arcpy.da.SearchCursor(source, ["OBJECTID"]) as cursor:
    ids = [row[0] for row in cursor]
    print(ids)
with arcpy.da.SearchCursor(source, ["OBJECTID", "CD_CS_FRA"]) as cursor:
    print(ids)
[1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60]
[39, 40, 41, 42, 43, 44, 45, 46, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 47, 48, 49, 50, 51, 52, 53, 55, 56, 54, 57, 58, 59, 60]
This happen with many different features class, but only in the Enterprise Geodabase. The same features class in a File geodatabase dont do this.
What could be the cause of that?
Tags (1)
JoshuaBixby
MVP Esteemed Contributor
In most database platforms, including Oracle, result set order is not guaranteed unless you use an ORDER BY clause.  If there is a need to guarantee an order in the cursor, you should specify the sql_clause parameter with an ORDER BY statement on the field you want ordered.
with arcpy.da.SearchCursor(source, ["OBJECTID"], sql_clause=(None,"ORDER BY OBJECTID")) as cursor:
    print(ids)
JoshuaBixby
    print(ids)
