Measure Results different
714
07-13-2017 11:45 AM
ShaningYu
I created an Add-In tool, which insert a feature from Source FC (S) into a Target FC (T).  The inserted feature's SHAPE.AREA and SHAPE.LEN values are automatically calculated.  In my code, the Area value is also calculated as shown below:
   IArea area = f_Target.Shape as IArea;
   double d_Area = area.Area;
The results show that      d_Area / SHAPE.AREA = 4.10754
I used the Measure Tool and found that the  SHAPE.AREA  value is CORRECT.
I could not figure out why the ArcObjects code is wrong.  Appreciate if you can help with your knowledge.
ShaningYu
Please ignore my Q since it was found that the source feature class has something wrong in its coordinate system setup.  Thanks.
