Hello all, I am trying to import files into the map, and I have succeeded to do with, using a drag and drop widget that I found in github, but I found an issue that I cannot display (import) Raster file, so the last solution I thought about is to publish some geoprocessing services that would import Rasters into the bring"em to the map,
so the service I published called Copy_Raster, with parameters
Parameter | Explanation |
Configuration_Keyword__2_ (Optional) | The configuration |
_CopyRaster | Output file |
c41078a1_tif | input file |
how can I use this service with ArcGIS API for JS, or do have a topic that would describe the steps to use the published services ...?
