AnsweredAssumed Answered
Why does Direction/Distance "shorten" distance units?
Question asked by jdlumber on Jul 11, 2017
Latest reply on Jul 12, 2017 by jdlumber
I've been working in ArcGIS Pro 2.0.0, and I've run into quite a strange issue with the Direction/Distance tool treating distance units as being "shorter" than they should be. I've reduced it to the following test case:
I created a new map using a projected coordinate system (NAD 1983 StatePlane Idaho West FIPS 1103 Feet) and added a polyline data set that was in the same CRS. I then used the Measure tool on a line segment and got a length of 125.09 feet.
Measure tool result
But when I use the Create tool feature to draw a new line over that same segment, the Distance tool gives me a much larger length.
Distance tool measurement
If I manually enter the "correct" distance of 125.09 feet, the resulting line is far shorter than expected.
It doesn't matter whether I just press the "D" key, right-click and select "Direction/Distance", or use the Dynamic Constraints button under the viewport; Arc acts as if a "Distance tool" foot is a lot smaller than a "map foot."
Is there something I could be doing wrong that throws the measurements off, or is Arc misbehaving?
Outcomes
