AnsweredAssumed Answered
Android 100.1.0 solveRouteAsync problem
Question asked by tuncakkoyun on Jul 11, 2017
Hi everyone! I'm getting not detailed error while i was trying to draw a route path.
Error is: com.esri.arcgisruntime.io.JsonEmbeddedException: Unable to complete operation.
can anyone help me!
thanks..
public void drawShortestPath(final Point startPoint, final Point endPoint) {
    // create RouteTask instance
    mRouteTask = new RouteTask(getContext(), getString(R.string.routing_service));
    UserCredential credential = new UserCredential(getContext().getResources().getString(R.string.arcgis_username), getContext().getResources().getString(R.string.arcgis_password));
    mRouteTask.setCredential(credential);
    setupSymbols(startPoint, endPoint);
    final ListenableFuture<RouteParameters> listenableFuture = mRouteTask.createDefaultParametersAsync();
    listenableFuture.addDoneListener(new Runnable() {
        @Override
        public void run() {
            try {
                if (listenableFuture.isDone()) {
                    int i = 0;
                    mRouteParams = listenableFuture.get();
                    // create stops
                    Stop stop1 = new Stop(startPoint);
                    Stop stop2 = new Stop(endPoint);
                    List<Stop> routeStops = new ArrayList<>();
                    // add stops
                    routeStops.add(stop1);
                    routeStops.add(stop2);
                    mRouteParams.setStops(routeStops);
                    // set return directions as true to return turn-by-turn directions in the result of getDirectionManeuvers().
                    mRouteParams.setReturnDirections(true);
                    // solve
                    final ListenableFuture<RouteResult> result = mRouteTask.solveRouteAsync(mRouteParams);
                    result.addDoneListener(new Runnable() {
                        @Override
                        public void run() {
                            try {
                                RouteResult res = result.get();
                                final List routes = res.getRoutes();
                                mRoute = (Route) routes.get(0);
                                // create a mRouteSymbol graphic
                                Graphic routeGraphic = new Graphic(mRoute.getRouteGeometry(), mRouteSymbol);
                                // add mRouteSymbol graphic to the map
                                mGraphicsOverlay.getGraphics().add(routeGraphic);
                                // get directions
                                // NOTE: to get turn-by-turn directions Route Parameters should set returnDirection flag as true
                            } catch (Exception e) {
                                Log.e(TAG, e.getMessage());
Outcomes
