symbols become squares in cache
553
07-10-2017 08:22 AM
AwesomeEvan
My point symbols in my cache are getting turned into getting squares... These should be handicap symbols
Any ideas why, or what I can try to remedy this?
should be
Tags (3)
JonathanQuinn
Esri Notable Contributor
If the service is rendered dynamically, do the symbols show up?  If not, you know it's not a problem with caching.  I would expect the same problem with a dynamic service.  It's likely that the handicap symbol font isn't installed on the Server machine, which is surprising because I thought that was a default symbol.
AwesomeEvan
I after setting it up a few times, this time I left it on rendering dynamically, when I was intending to cache...
I set it to a cached tile service and all is well.
