AnsweredAssumed Answered
Convert GxDialog to Workspace
Question asked by warpengine on Jul 6, 2017
Latest reply on Jul 7, 2017 by warpengine
ArcGIS 10.1 with VB2010
I am using the GxDialog to get the users option to save a feature class. The target can be a shapefile, geodatabase, or Dataset inside a geodatabase.
I can’t wrap my head around how I am supposed to parse the Workspace, FeatureDataset, and FeatureClass name to use in creating the feature class.
So far I have
            'setup the save dialog
            Dim pGxDialog As IGxDialog = New GxDialog
            Dim pGxObjFilterSh As IGxObjectFilter = New GxFilterShapefiles          'shapefiles
            Dim pGxObjFilterPg As IGxObjectFilter = New GxFilterPGDBFeatureClasses  'personal geodb (Access db)
            'Dim pGxObjFilterFg As IGxObjectFilter = New GxFilterFGDBFeatureClasses  'file geodb (ESRI db)
            Dim pGxObjectFilterCollection As IGxObjectFilterCollection = CType(pGxDialog, IGxObjectFilterCollection)
            pGxObjectFilterCollection.AddFilter(pGxObjFilterSh, True)
            pGxObjectFilterCollection.AddFilter(pGxObjFilterPg, False) 'this one actually contains both file and personal geodb feature classes
            'pGxObjectFilterCollection.AddFilter(pGxObjFilterFg, False)
            'get the users selection (it can be a shapefile or a geodb). Catalog paths consist of two parts: the workspace and the base name.
            If pGxDialog.DoModalSave(MyApp.hWnd) Then
                Dim catalogPath As String = My.Computer.FileSystem.CombinePath(pGxDialog.FinalLocation.FullName, pGxDialog.Name)
                Dim workspaceCategory As String = pGxDialog.FinalLocation.Category
                Debug.Print(String.Format("catalogPath={0}, workspaceCategory={1}", catalogPath, workspaceCategory))
                Debug.Print("ClassID={0}", pGxDialog.FinalLocation.ClassID)
                'I can use the workspaceCategory to get the target type. But how do I split out either the entire string path or
                'the pGxDialog to create a Workspace object. How do I set up the objects to allow a Feature Dataset?
          Select Case workspaceCategory
              Case "Personal Geodatabase", "Personal Geodatabase Feature Dataset"
                  'personal geodb (Access database C:\myData\mypGDB.mdb)
                  wkspFactory = New AccessWorkspaceFactory
                  pCLSID.Value = "esriGeodatabase.Feature"
              Case "File Geodatabase", "File Geodatabase Feature Dataset"
                  'file geodb (File database C:\myData\myfGDB.gdb)
                  wkspFactory = New FileGDBWorkspaceFactory
              Case "Folder"
                  'shapefile (c:\mydata\)
                  wkspFactory = New ShapefileWorkspaceFactory
                  pCLSID.Value = "esriCore.Feature"
              Case Else
                  Throw New Exception("Unsupported workspace category: " & workspaceCategory)
          End Select
            End If
Outcomes
