WAB Themes Missing
1235
07-02-2017 04:31 PM
JamesPreston1
Hi everyone!
Since the latest June 2017 WAB update I have been unable to select which type of theme I would like on a new hosted WAB application. The theme tab is just empty:
An image of the WAB configuration screen with an empty themes tab.
This only appears to be happening with newly created WAB apps. I am able to go into existing WAB apps and select themes.
I did recently setup some organisational "shared theme" colours, could this have something to do with the problem? I looked to see if there was a "reset to default" option or similar for shared theme, but there is nothing.
Does anyone have any suggestions?
JamesPreston1
The issue seemingly resolved itself. AGOL works in mysterious ways.
RodLockie1
I have this same problem. Also possibly the same reason as our agol organisation has shared themes set up.
It would be good to know if this will be fixed soon.
JamesPreston1
