Find Nearest tool failed
762
06-30-2017 05:36 AM
KrisReinertson1
New Contributor III
. Both feature services I'm using have under the 1,000 feature maximum. I'm only looking for one nearby feature per feature, so I'm definitely under the 100 maximum for number of nearest locations. Both feature services used in the analysis tool have less than the 1000 feature limit. I have network analysis privilege. When I filtered for only one feature and ran the tool to find its nearby feature, it ran smoothly. Now, when I try running the tool on all 900+ features, I receive an Error message saying "Error   Find Nearest Failed."
 Here are the parameters I'm setting for the tool:
1. Selected Feature Service of starting point features
2. Selected Feature Services of potential nearest locations (point features)
3. Drive Time
               Use traffic Enabled
               Traffic based on typical conditions for Monday 12:00 P
4. For each location in the input layer
               Limit the number of nearest locations to: 1  Enabled
               Limit the search range to Disabled  (Also tried enabling this and still received Error message)
5. Layer name provided
               Include route layer Disabled
               Use current map extent Disabled
Please help.
KellyGerrow
Esri Frequent Contributor
Thanks for reporting the issue.
I can't reproduce the issue in a quick test. Can you share your web map or contact technical support to investigate what is causing the issue.
-Kelly
