I need to generate some .tpk files for use with our .net application (uses ArcGIS 10.2.7 for .net). The old version of ArcGIS for Desktop (V10.4) had a bug which prevented generation of .tpk files. Can anyone confirm if ArcGIS Pro is able to successfully save .tpk files?
according to the help tools are there
Dan, thanks I'll download the 60 day trial and check that it works (a bug prevented .tpk export from working in Desktop 10.4).
make sure that you consolidate the maps prior to using the tools for tpk. This issue came up earlier this week and that step was missed and although the help file is explicit about what is needed for the tool.... there should be a big bold-faced font used on the required inputs. Good luck
