How to await MapView with TypeScript
1664
06-20-2017 01:02 PM
AlanMervitz
I'm using TypeScript and wondering if there's a better way to await a MapView than what I'm currently doing. The example in the documentation shows how to supply a callback for the then promise when using vanilla JavaScript:
var view = new MapView();
view.then(function(){
  // This code will execute once the promise is resolved
What I'd like to do is use the await keyword to avoid the nested function call. This is the only way I've been able get this to work:
let view = new MapView();
await view.then(() => {});
Ideally I would be able to write something like this:
await view;
// this code will execute after the promise is resolved
Although it doesn't compile with this error:
Type of 'await' operand must either be a valid promise or must not contain a callable 'then' member.
Alan
ThomasSolow
I haven't started using await yet but if I get a chance I'll try this out and see if I can replicate this issue.
Promises returned by the JS API tend to be a little different from the standard JS promises and this could possibly be related to this issue (the type is IPromise, based on dojo/deferred): jsapi-resources/arcgis-js-api.d.ts at master · Esri/jsapi-resources · GitHub
