Basemap zooming level
1473
06-17-2017 05:33 PM
MichaelHeyroth
New Contributor III
I have a custom basemap hosted online. Using Arc collector I can zoom in extremely close but when I using the same basemap in the Arc Explorer app it only lets me zoom into about a street level, Any ideas on how to zoom in closer? Thanks in advance.
MichaelHeyroth
New Contributor III
Figured it out.
My custom basemap was restricting me.   Once I added the streets basemap along with my 3inch high res. orthos it will let me zoom right in and fully use my 3 inch maps.
The streets map must allow zooming in closer.
All good
AdrianWelsh
MVP Honored Contributor
Michael,
I am guessing that the zoom restrictions are based on the default basemap of explorer and not based on your basemap. I wonder if you could remove the default basemap (assuming your map can zoom in further than Esri's) and make your basemap the only one there. Otherwise, I am not sure that there is a solution to this - and just a restriction of Explorer.
MichaelHeyroth
New Contributor III
Figured it out.
All good
AdrianWelsh
Nice work Michael! You should mark your reply as the correct answer to close out this thread.
