Edited records stuck in Outbox (v. 2.1.6); error code 500
822
06-16-2017 11:28 AM
SamanthaNakata1
I currently have a Survey 123 form running on an enterprise layer and related table, attachment table.  If I initiate a survey and send it, that works fine.  If I go to the Sent box, edit the survey, and send the survey, no updates are made (record remains in Outbox).
I get the following error:
Send Error
This survey was not able to be sent due to the following error:
Code 500
Unable to complete operation.
Tags (3)
JamesTedrick
Esri Esteemed Contributor
Hi Samantha,
It's a bit hard to diagnose from just the description of the error message.  A couple of things to check:
- is the service set up to allow for updating of data in addition to adding data?
- is the service set up with the Sync capability?
If you can generate a log file (see Troubleshoot—Survey123 for ArcGIS | ArcGIS ; instead of logging to a console, it can save to a file in <user director>/ArcGIS/AppStudio/Logs ) and forward that along (feel free to e-mail me at jtedrick @ Esri.com) that will help understanding the issue.
