"Failed to create service essai MapServer. Service failed to initialize: Feature service creation failed. hr=0x80040067 No Layer or Table was initialized
818
06-16-2017 08:24 AM
ManelKEDDAR
New Contributor III
Hello every one ,
Need help , i'm having this error and i'm trying to access to a feature table named essai of my geodatabase named Test so i ve athored a .mpk file and i'm trying to access to this file so i can add on it a geometry so i used the local server and local services here's my code :
private Esri.ArcGISRuntime.LocalServices.LocalServer _localServer;
private async void StartLocalServer()
//get the singleton LocalServer object using the static instance property
_localServer = Esri.ArcGISRuntime.LocalServices.LocalServer.Instance;
//Handle the statusChanged event to react when the server is started
_localServer.StatusChanged += ServerStatusChanged;
//Start the local server instance
await _localServer.StartAsync();
private async void ServerStatusChanged(object sender , Esri.ArcGISRuntime.LocalServices.StatusChangedEventArgs e)
//Check if the server started successfully
if(e.Status == Esri.ArcGISRuntime.LocalServices.LocalServerStatus.Started)
//Create a local feature service from a map package on disk
LocalFeatureService featureService = new LocalFeatureService(@"C:\Users\mkeddar\Documents\ArcGIS\essai.mpk");
//Handle the status changed event to check when it's loaded
featureService.StatusChanged += async (svc, args) =>
//If started successfully , add a layer from the service
if (args.Status == LocalServerStatus.Started)
//Get the service URL
var featureServiceUrl = (svc as LocalFeatureService).Url.AbsoluteUri;
//Create a new service feature table
ServiceFeatureTable localServiceTable = new ServiceFeatureTable(new Uri(featureServiceUrl + "/2"));
//Create a new feature layer to display the features in the table
FeatureLayer featureLyr = new FeatureLayer(localServiceTable);
var attribute = new Dictionary<String, object>();
attribute.Add("description", "description");
var geomCone = createCone3D();
//create a new feature
var newFeature = localServiceTable.CreateFeature(attribute,geomCone); // here i don't know what to guive as parameters so i create a feature
//from my geometry geomCone
//add the new feature
await localServiceTable.AddFeatureAsync(newFeature);
//push this update (apply edits) to the feature service
IReadOnlyList<EditResult> editResults = await localServiceTable.ApplyEditsAsync();
//check the results for errors
foreach(var r in editResults)
if (r.CompletedWithErrors)
Console.WriteLine("Edit ti Object" + "'failed'" + r.Error.Message);
//Start the local feature service
await featureService.StartAsync();
i don't know where's the problem any one can help me please thanks in advance
