AnsweredAssumed Answered
Saving an MXD with a datetime2 field from 10.5 to 10.2
Question asked by straatvark on Jun 14, 2017
Latest reply on Jun 15, 2017 by straatvark
Hi
We have version 10.5 MXDs that use spatial data from a none-SDE sql database. It include the datetime2 attribute type on feature classes.
When this is saved as a version 10.2 MXD and opened in our 10.5 environment it still works.
When this 10.2 MXD is moved to a 10.2 environment that require a data source repair - then we get an 'invalid field type' error when the data repair window of the layer is opened.
We tested the exact same scenario using datetime as a sql data type instead of datetime2 - then there is no problems.
But 0.2 support datetime 2:
http://resources.arcgis.com/en/help/main/10.2/#/SQL_Server_data_types_supported_in_ArcGIS/002q00000068000000/
This support is proven if we open our version 10.2 'datetime' test MXD in the 10.2 environment and point it to a feature class that have datetime2. It works.
So the problem that we have is: We cannot do a data source repair in ArcMap 10.2 on layers that have a datetime2 attribute type.
Anyone with advice please?
Outcomes
