App crashes randomly with (0xc0000005) 'Access violation'
7001
9
06-08-2017 12:55 AM
KarinGisperg1
We are developing an app with ArcGIS Runtime .NET 100.0.0, that offers interaction with offline maps.
In general we are using the MVVM Model. The MapView.Map binds to a ViewModel.class Map Property CurrentMap.  This class also contains a  Map Property OfflineMap, which holds reference to a corresponding Map with offline-content .
During initial loading (with some async stuff in previous steps), the (offline) Layers are attached to  the OfflineMap Map and after awaiting OfflineMap.LoadAsync(); the Property CurrentMap is assigned to OfflineMap.
Our problem is that the app crashes randomly at the line
this.ProjectManagerViewModelInstance.CurrentMap = this.ProjectManagerViewModelInstance.OfflineMap;
with an exception we cannot handle.The output window shows:
[…MyApp...]WPF.vshost.exe' has exited with code -1073741819 (0xc0000005) 'Access violation'.
public async Task LoadProjectWithTaskSampleAsync(
            object param)
            try
                #region checkProject
                // our "progressbar"
                this.ToogleReporter("CheckProject",true);
               //read project information from parameter
                var pi = await this.ProjectManagerViewModelInstance.InitConnectionInformationAsync(param);
                if (pi == null)
                    Log.Warn(" ... ");
                    this.ToogleReporter("CheckProject",false);
                    return;
                 #endregion checkProject
                this.ToogleReporter("LoadProject", true);
                 //MAP CREATION AND ASSIGN TO OFFLINE MAP PROPERTY (and other stuff like processing  layer infos ...)
                await this.ProjectManagerViewModelInstance.LoadProjectAsync(pi);
                // check if all information could be loaded properly
                if (await this.TryToOpenProjectAsync(pi))
                    this.ToogleReporter("LoadProject", false);
                    Log.Error("...");
                    return;
                // Check if offline map has layers
                var offlineMapAllLayers = this.ProjectManagerViewModelInstance?.OfflineMap?.AllLayers;
                if (offlineMapAllLayers != null && offlineMapAllLayers.Any())
                    Log.Debug("Await call OfflineMap.LoadAsync()");
                    await this.ProjectManagerViewModelInstance.OfflineMap.LoadAsync();
                IsLoadingProject = false;
            catch (Exception e)
                Log.Error("Loading Project Failed. Abort! ",e);
            finally
                this.EndOfLoadingProject();
The offline map contains 1 vtpk (52 MB), 1 tpk (15 GB) and 2 mmpks(85 MB and 3 MB). The problem seems to occur only on offline maps with *.mmpks (but still randomly).
Can you help us? I attach the memory dumps, maybe it helps.
Thank you
We are using:
Microsoft Visual Studio Professional 2015
Version 14.0.25421.03 Update 3
Microsoft .NET Framework
Version 4.6.01586
Installed Version: Professional
Visual C# 2015   00322-40000-00000-AA460
Microsoft Visual C# 2015
ArcGIS Runtime SDK for .NET   100.0.0
Microsoft Windows 10 Enterprise
PhilScovis
New Contributor III
We are getting this issue too, in a UWP environment.  It also happens intermittently, although we have a path that will reproduce it fairly regularly.
Exception thrown at 0x00007FFEC68549B7 (RuntimeCoreNet.dll) in xxxxxxxxxxx.exe: 0xC0000005: Access violation reading location 0x000002263BBBF61C.
FWIW, the disassembly:
00007FFEC685498F mov rsi,rcx
00007FFEC6854992 mov qword ptr [rsp+50h],r8
00007FFEC6854997 mov r12d,r13d
00007FFEC685499A mov qword ptr [rsp+58h],rcx
00007FFEC685499F mov qword ptr [rsp+60h],rax
00007FFEC68549A4 mov qword ptr [rsp+70h],r13
00007FFEC68549A9 test rcx,rcx
00007FFEC68549AC jne 00007FFEC68549B7
00007FFEC68549AE lea r8,[7FFEC7A6A99Ch]
00007FFEC68549B5 jmp 00007FFEC68549DD
00007FFEC68549B7 mov eax,dword ptr [rcx+5Ch]
00007FFEC68549BA cmp eax,0A029A697h
dotMorten_esri
Esri Notable Contributor
"Access Violation" is the equivalent of a Null Reference Exception, so there's no guarantee these at the same bugs.
Thank you for the dump file, but this appears to be a mini-dump which doesn't have all the information necessary to debug it in our end. Can you either provide a full dump (they are usually up towards 1gb in size), or a stand-alone sample that reproduces the problem?
PhilScovis
New Contributor III
Whom can I send an application dump to?  I don't want to post it here.
dotMorten_esri
Thanks Paul. I got the dump, and the crash is definitely unrelated to the crash in this post.
PhilScovis
New Contributor III
Thanks for looking at it.
dotMorten_esri
@Karin After some more research it looks like there's a threading issue happening in the vector tile layer. We've made significant changes in this specific area since v100.0. We are weeks away from releasing v100.1, so could you retry with that version? Our best guess (without an in-house reproducer) is that this issue has been addressed already.
Stefan_Jung
There is still a problem using vector tile packages with ArcGIS Runtime v100.1 on Windows Mobile 10.
I've created a default ArcGIS Runtime App (Univeral Windows) project and initialized the Map with a local vtpk.
This works fine on the "Mobile Emulator for Windows" but the app crashes on a real device.
The vtpk is visible on start but when zooming-in the app crashes with following:
The program '[3952] UWPSample.exe' has exited with code -1073741819 (0xc0000005) 'Access violation'.
dotMorten_esri
Which mobile device are you using?
Stefan_Jung
This is my (old) Test Device:
Lumia 550
Version 1703
OS-Build 10.0.15063.483
