item description does not refresh from map document properties
639
06-06-2017 12:16 PM
HunterCarver
When I edit map document properties and go to overwrite existing service, the item description in the Service Editor does not refresh
DerekLaw
Esri Esteemed Contributor
Hi Hunter,
This is more of an ArcMap related question, specifically on publishing a web service. Hence why I am moving it from 'Web AppBuilder' and into the 'ArcGIS for Server' forum.
What release of ArcMap are you using? And can you please provide detailed repro steps and screenshots?
RandallWilliams
Hi Hunter,
This looks to be related to the following issue:
[#ENH-000095154 Allow modifications to a map document’s metadata to update the map service’s Item Description when overwriting a service]
I'm unsure about a time frame when this issue may be addressed. If you'd like, you can log into myEsri and ask that your customer number be added to list of users who have inquired about this issue.
