Unable to invite member to arcgis online organisation
2149
06-05-2017 03:58 AM
MarkNewman
I am unable to invite a member to the organisation, there is an apostrophe in his email address, has anyone had this issue? If so is there a way around it?
RebeccaStrauch__GISP
Have you tried Invite and add members—ArcGIS Online Help | ArcGIS   the option "without sending an email"?  I'm not sure if that will let you bypass that issue or not.
MarkNewman
Hi Rebecca, Yes that worked.
Many thanks,
Mark
Glad to hear it worked.  remember to mark the answer as correct to close this thread.
shan_sarkar
Occasional Contributor III
Mark,
The user name must contain 6 to 128 alphanumeric characters. You can also use the following special characters: . (dot), _ (underscore), and @ (at sign). Other special characters, nonalphanumeric characters, and spaces are not allowed. The user name cannot be the same as the password. Once you send the invitation, the user name cannot be changed by you or the member.
Please refer, Invite and add members—ArcGIS Online Help | ArcGIS
It has been mentioned in the documentation.
I hope this helps!
~Shan
~Shan
