AnsweredAssumed Answered
EOS Arrow Gold RTK with Collector
Question asked by adam.prins_aarchaeologya on Jun 2, 2017
Latest reply on Jun 2, 2017 by KBurke-esristaff
I am currently trying to survey in Israel with my new EOS Arrow Gold RTK, which allows for sub-cm accuracy and can be used in place of the native iOS/Android GPS sensors. Collector is what the manufacturer recommends as a datalogger, and it seems to be an ideal solution.
Here's a short explanation of my needs and issues. I need to collect my points natively in Israel Transverse Mercator (Israel_TM_Grid ID: 2039) at cm accuracy. My RTK network provider here in Israel receives corrections in WGS 1984, and my RTK device is receiving the network corrections properly and getting the required accuracy.
So, I set up a location profile in Collector on an iPad to transform from WGS 1984 to Israel TM, using WGS_1984_To_Israel_Coordframe. I published a map and feature class on ArcGIS Online in Israel TM, using my own orthophoto (which is projected in Israel TM) as a basemap, but each time I try to open the map to take a point I get an error saying that the location profile does not match the map (but it does!). I've tried different combinations of transformations, remade and republished the map, and I'm not able to collect points in Israel TM.
Basically, my needs are quite simple: I need be able to collect x, y, and z coordinates in Israel TM. WGS84 lat long won't work for my purposes, for a silly long-winded reason that's not relevant. I'd greatly appreciate any help you can provide, as this beautiful $8,000 device is pretty useless to me without this functionality.
Thanks!
Outcomes
