ARCMAP-METADATA
511
05-30-2017 06:21 AM
ChuckTurlington
Occasional Contributor II
I am using ArcMap 10.4.1.
I have been reviewing Transformations and Projections for certain coordinate changes and came across some information in an article that reads: "When using the Project Tool, the transformation method applied is recorded in the metadata".  I have tried to find this Metadata that describes the Transformation and/or Projection performed on my data as a check.  Is there a button click to get access to this information ?
JayantaPoddar
MVP Esteemed Contributor
Did you check Item Description (From ArcCatalog > Right-click the feature class > Item Description).
Metadata1
Metadata2
Think Location
JayantaPoddar
Metadata1
Metadata2
Think Location
